HTPC - Vista Media Center - Problem Playing Dual Audio Channel Video Files
27 Jun 2007
Apologies, if posted in wrong forum, was uncertain as to where best placed :)
Have a HTPC running Vista Media Center. I have several .avi files which have different languages running on different audio channels. I use FFDShow codec for the video (by way of My Movies in VMC). The audio I am guessing actually uses AC3 as the FFD Audio does not pop up for these; where it does for .mkv's etc. What I am hearing though is both audio channels (so two languages at the same time). How do I flip between channels, effectively allowing me to only hear the English channel? Is there an easy way to do this? I did have a look through AC3 settings although could not see anythign apparent.
Help would be very much appreciated
Try enabling the relevant audio codec in ffdshow so that you can use that to select the stream that you want.
Also, I think vobsub should be able do what you want.
