HTPC/VR Rig
14 Aug 2011
Morning All
Just need a sense check before I hit buy
My basket at Overclockers UK:
Total: £1,539.83 (includes shipping: £0.00)​
focus 650/antec 650 unit! or whisper which is tier 1
Total: £274.07 (includes shipping: £11.10)
Maybe get an nvme drive instead of the M2 drive?
They are supposed to be a lot quicker
And how about 16 GB of ram :)
Dump the bundle you are getting ripped off. If you select the components on their own Mobo/CPU/RAM it's £517.97, so you are paying £21 towards your FREE SSD, also the motherboard is far too expensive for an X370 version, as OCUK have it marked up much higher than it can be had else where ~£120-30, so again your FREE SSD is being fully paid for by these inflated prices.
Grab a good B450/X470 board, the 2700X, and you should probably up it to 16GB RAM if you are using it for VR. I'd probably get the parts listed below.
Total: £549.47 (includes shipping: £10.50)​
You don't get the "FREE SSD" but you get 16GB DDR4 3000MHz RAM, and a full featured board with a decent VRM, that will be more than happy running the 2700X - and the cost is the same as the kit. :)
For the record im using the board and cpu to update my main rig with the 1700 i have going in the HTPC. Not sure if i should keep the card for my rig or stick with the sli 980ti
Just a question but i have an msi b450-a pro. I took this option so i had more money for some 3200 ram that was compatable with the boards xmp profile.
What benefit would having a 470 over a 450? Unless i was wanting 64gb of ram i see no difference?
