less than £50 second hand, arcam alpha x or marantz of some description
Ok what if you wanted your HTPC to give out equivalent of £1000+ 'audiophile' sound quality. What sound card or DAC would would be good to put in?
I'd go with a standard soundcard, digital out -> Benchmark DAC-1. Although I think that would be overkill unless you had a very, very very good room + speakers.
Why would you choose standard digital out over USB?
a Beresford 7520 DAC + TH4032 opamp upgrade is amazing for the money, i've never heard the Benchmark DAC with my gear so it's not easy to compare but when i listened to it at some shows it's definitely not £800 better.
upcoming WADIA DAC should be a nice one though.
What is the rest of the system, amp and speakers being used ?.
Use external DAC, either SPDIF, or USB should be a bit better..... Or go one step further and use a NAS drive and Digital Streamer.
What the budget your working with ?
I wouldn't have thought either would make much difference - although USB probably has better error correction, but a USB Benchmark is quite a bit more expensive.
I've found this review on sterophile of the Benchmark DAC 1 USB and the reviewer claims the sound is bit more grainy over USB than SPDIF/AES. Though I don't understand how it would be more grainy.
Well, would help if the reviewer defined "grainy".
I was wondering what amount of money would you need to spend on a dedicated CD player to get the same quality as HTPC running lossless audio out with a decent pc sound card like a Creative Sound Blaster X-Fi Titanium?
usb2.0 has more than enough bandwidth192khz 24bit stereo pcm is just over 9Mbps but usb2.0 has bandwidth enough to stream a hd-dvd at least which works out about 30Mbps. . usb2.0 is theoretically capable of 480Mbps (60MBytes) and i know ive seen 45-50 using a 2.5" portable drive.
