HTPC's in the System Builder Option
7 Mar 2007
Kent
Think this is the best place to ask.
I have looked and cannot find anything, unless I am being completely blind, but I have looked at the system building for the HTPC machines (The Verso Pro and Verso Edge options) but I cannot see anywhere it mentioning what graphics card it has in it, or even an option to add a graphics card.
Is anyone able to confirm?
When you go to the system you want to order their is a few options before you select buy. You can usually choose what operating system you would like installed, Hard drive upgrades or memory upgraded and you can also select if you would like onboard graphics or a graphics card. Their is a list of cards available in the drop down box for the graphics card upgrade.
