HTTP headers!
26 Dec 2003
London
Can someone well versed in the intricacies of murky HTTP magic tell me why the heck this produces corrupt downloads for some people?
Code:
header('Content-Type: application/zip');
header('Content-Disposition: attachment; filename='.basename($filename));
header('Content-Length: '.filesize($filename));
readfile($filename);
$filename is and always will be a zip file, so I don't need to mess about with dynamically working out the mime-type. As far as I and Google know, application/zip is universally understood, so it can't be that. From examining the headers sent, the content-length is accurate, and the filename is being set in the content-disposition line.
The trickiest part is that I am totally unable to reproduce the errors myself; Firefox, IE, Opera and humble wget all download the zip fine and it's totally intact/well-formed. I'm totally pulling my hair out :(
I'd appreciate some help debugging, so if you don't mind downloading this zip file and - provided you get a corrupt file - posting your browser/OS/zip utility, I'd really appreciate it. Otherwise I'll just presume no news is good news and ignore it :)
:confused: strange , it might be the other users browser setup because i used to always get corrupt drivers from ATI.com till i formatted! - No one else I knew did :confused:
I found this which seems confirmed on php.net/header - seems that some versions of IE like to ignore Content-Disposition.
Apparently, IE also needs 'Pragma: public' for some quirky reason.
Lastly, 'Content-Transfer-Encoding: binary' may be useful but I shouldn't think it's necessary...seems to work alright on whatever I download, and I've never seen it before this research :)
Tried adding those. It's the weirdest bug I've ever come across though; one user said this:
"I am presently in LA; here is where I downloaded a corrupt file. When I remotely connected to a computer in Chicago a few minutes ago, I downloaded the file uncorrupted. Interesting."
Have you got a checksum of the original file we can compare against? If the checksum matches for people, but the zip is still considered corrupt, then you I guess you can rule out transmission errors and put it down to the zipping software. I've seen occasions where regular .zip files will open with a program like 7zip, but not others - which may be down to tolerance of errors/error correction ability.
Server not responding for me at current; will try later :).
