Huawei B535 antennas
11 Jun 2003
The Shadows (london)
Does anyone know of any inexpensive but decent antennas for this mobile router?
The signal in my area is terrible.
Cheers
Soogs
Your best friend in this scenario is usually height, if you can either move the router up higher or use external antennae’s situated up a height, you are more likely to see an improvement, but it depends on the local environment.
My post code doesn’t get 4g only 3G.
I could try getting power up into the loft but I’m sure when I tried the sim card out on the streets near my home it was still only connecting with 3G which is why I was thinking some better antennas might help me pick up a 4g signal.
Even if I’m just on the outskirts of it? I think like 2 roads down there is 4g
A better external may help. I'm on the periphery of 5G and tried to utilise it but it was that weak I just gave up (returned the kit for a 30 day refund). I was just using a better internal aerial. It's a gamble though. If it doesn't work then it's money wasted. But I'd imagine if you desperately wanted to try then you'd need a good external aerial up on the roof or along the facia outside (as mentioned height is best to avoid obstacles etc). Then trial and error to try and get a good signal before finally fixing in place.
I recently asked Taoglas what external aerial they recommend (as I use one of their internal antenna and was curious what external they'd recommend) and they said this one - https://cdn2.taoglas.com/datasheets/MA741.B.BI.001.pdf - but that is roughly £150. I've also seen those directional aerials that look like TV aerials. Not sure how good they are.
If you’re in a marginal signal area the something like the Mikrotik SHG LTE might pull in a signal, but it also might not.
https://mikrotik.com/product/lhg_lte_kit
The other seriously sensitive option is the Mikrotik LDG LTE which attaches to a spare slot on your satellite dish (if you have one) and the gain on that is phenomenal. We put one of those into a farm in deepest, darkest, Lincolnshire and the farm went from a 5Mbps 3G connection to a 55Mbps 4G signal and it was even easy to cable up.
https://mikrotik.com/product/ldf_lte6_kit
