Huawei P30 Pro Status Bar
29 May 2019
I don't know if i have a setting enabled or what (doesn't change whether dark mode is on or not) But the first image is the Huawei P30 Pro with the notch disabled. This image shows the icons white. However, as soon as the notch is enabled, the icons turn black and it makes it impossible to read
Anyway to make the icons white while the notch is disabled?
