Hue LED strip V channel diffuser
  • Thread starter Thread starter GeX
  • Start date Start date
GeX
GeX
17 Dec 2002
Manchester
Can anyone recommend a diffuser for the Hue LED strips (the basic ones, not the Gradient or Outdoor models).
I want to fit it under the lip on a high sleeper bed, so ideally want a V channel diffuser so that the strip is angled at 45 degrees.
There are lots on Amazon, but finding one with a wide enough (15mm) channel for the strip is proving tricky. I need corner sections too.
Has anyone here used any of these diffusers?
