Hi folks
I am currently in the process of overclocking my new Q9550. I have it set at 3.2 for the time being but real temp is showing odd results. Under a stress test core 1 and 2 and at 53 deg and 3 and 4 are at 36 and 33 respectively. I believe the lower temps are the correct temps as it is being water cooled and my old e8400 would have been this hot!
I am considering reseating the water block but its not going to be easy as the loop is fairly tight and hard to get into
Is there any other software I could use to test? Motherboard is a dfi LAN party jr p45-t2rs
Cheers
Cheers
