Huge Intel and DDR5 problem needs fixing!
So the problem is...you cant run memeory speeds loads higher than the officially supported speed..
What?
It's the first gen DDR5 memory controllers, surely that's to be expected? Takes a while for it to mature, we've seen the same thing with DDR4,3,etc.
Y
Yup that's right but for some whom buy the expensive boards "Extreme" etc and 4 sticks of fast ram they just expect it to work out of the box and that's just not gonna happen this early on.. I've seen 6400 and good timings with 4 sticks but that's with a top 1% CPU which also does 7400mhz C30 stable
I wasted weeks trying to get four DDR4 Corsair Vengeance RGB Pro sticks to work at advertised speeds and timings.
I had a right load of blue screens and random crashes.
3500Mhz worked, 3600 did not.
Then Asus put out a motherboard BIOS update, and ta-da, everything worked as advertised.
