** Huge Price Drops on Noctua and Be-Quiet Cooling Solutions **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have new pricing in place for Noctua and Be quiet coolers at OcUK
Fans from these brands will be seeing much better pricing over the next few days also.
This is new pricing, not a special offer, not for a limited time.
if you are looking for a new cooler, these are the brands to be buying.
Noctua NH-D14-2011 Dual Radiator CPU Cooler with PWM Fans (Socket LGA2011) @ £59.99 inc VAT
Having received more than 250 awards and recommendations from the international press, Noctua's NH-D14 has become a benchmark in premium quality quiet cooling. The SE2011 version is a special edition for Intel's Core i7-39xx/38xx (Sandy Bridge-E) high-end platform and comes equipped with the new SecuFirm2 mounting system for LGA2011. Combined with the exquisite NF-P12/NF-P14 dual PWM fan configuration and topped off with Noctua's renowned NT-H1 thermal compound, the NH-D14 SE2011 is an elite choice for an elite platform.
Award-winning NH-D14 cooler
Tens of thousands of enthusiast users all over the world swear by the NH-D14's quality and performance. Recommended by more than 250 international hardware websites and magazines, it is renowned as one of the best high end coolers on the market.
Six heatpipe dual radiator design
Providing more surface area, better heat distribution and superior airflow efficiency than conventional tower style heatsinks, the NH-D14's six heatpipe dual radiator design was developed to provide ultimate quiet cooling performance in dual fan mode.
Dual NF-P14/NF-P12 PWM fan setup
The NH-D14 sports a premium quality dual PWM fan setup consisting of Noctua's award-winning NF-P12 (120mm) and NF-P14 (140mm) fans, both of which feature Vortex Control Notches, SCD technology and SSO Bearings in order to achieve a perfect balance of performance and quietness.
Custom designed PWM IC with SCD
Supporting fully automatic PWM speed control, the NH-D14 SE2011's NF-P12 and NF-P14 fans use Noctua's novel, custom designed NE-FD1 PWM IC that offers Smooth Commutation Drive (SCD) technology. By providing smoother torque impulses, SCD suppresses PWM switching noises and thus makes the fans quieter at lower speeds.
Excellent component cooling
Hanging out at the bottom of the fin stacks, the NF-P14 fan doesn't only contribute to the NH-D14's superb CPU cooling capabilities but also provides massive airflow over the surrounding motherboard components and heatsinks, thus ensuring excellent component cooling performance.
Noctua's enthusiast grade SecuFirm2 systems meet the highest demands in safety, contact pressure and ease-of-use. Tailor-made for LGA2011, the new NM-I2011 mounting brings the trusted SecuFirm2 quality to Intel's new Core i7-39xx/38xx platform.
Noctua's much-acclaimed NT-H1 is a well proven pro-grade TIM (thermal interface material) solution that provides minimum thermal resistance, excellent ease-of-use and outstanding reliability.
- Noctua's popular NH-D14 for LGA2011
- Excellent choice for Intel's newest CPUs
- Supplied with two all new PWM fans
- Includes NT-H1 thermal compound
- Height (with fan): 160 mm
- Width (with fan): 140 mm
- Depth (with fan): 158 mm
- Fan Speed: 1300 RPM
- Air Flow: 54.3 CFM
- Fan Noise: 19.8 dB(A)
Was £72.98 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Noctua NH-C14 Top-Flow Low-Profile CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £59.98 inc VAT
The NH-C14 brings top-flow cooling to a new level by offering an exquisite, uniquely flexible 140mm dual fan setup: The two supplied NF-P14 premium fans can be installed on top and underneath the fin-stack to configure the cooler for maximum performance in dual fan mode and either lower profile (105mm) or maximum component clearance in single fan modes. Bundled with the award-winning NT-H1 thermal compound and Noctua's SecuFirm2 multi-socket mounting system, the NH-C14 is a highly flexible, premium-class top-flow solution that further boosts the renowned quiet cooling performance of the much acclaimed NH-C12P series.
- Six heatpipe C-type design
- Two NF-P14 140mm fans supplied
- Three different installation options
- Excellent component cooling
- SecuFirm2 multi-socket mounting system
- NT-H1 thermal compound
- Socket LGA1366, LGA1155/6, LGA775, AM3, AM2+, AM2 compatible
- Fan Speed: 750 - 1200 RPM
- Fan Noise: 10.1 - 19.6 dBA
- Fan Airflow: 71.2 m³/h - 10.3 m³/h
- 6 Year Warranty
Was £69.98 Inc. VAT
Only £59.98 inc VAT.
ORDER NOW
Noctua NH-C12P SE14 CPU Cooler - (Intel LGA1366/1156/1155/775/2011/AMD AM2/AM2+/AM3/AM3+/FM1) @ £49.99 inc VAT
Building on the proven basis of the successful NH-C12P, which has received more than 100 awards and recommendations from the international press, the NH-C12P SE14 now comes with Noctua's new NF-P14 140mm fan for further improved quiet cooling performance as well as the new SecuFirm2™ multi-socket mounting system. Topped off with Noctua's pro-grade NT-H1 thermal compound and adding support for both LGA1366 and LGA1156/1155, the NH-C12P SE14 is a premium quality quiet cooler that provides lots of airflow for near-socket mainboard components and excellent case compatibility at a height of only 114mm.
- Socket compatibility: Intel LGA1366, LGA1156, LGA1155, LGA775, LGA2011 on request, Asus X-socket™ & AMD AM2, AM2+, AM3, AM3+, FM1 (backplate required)
- Height (without fan): 90 mm
- Width (without fan): 126 mm
- Depth (without fan): 152 mm
- Height (with fan): 114 mm
- Depth (with fan): 152 mm
- Weight (without fan): 550 g
- Weight (with fan): 730 g
- Material: Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
- Fan compatibility: 140x140x25mm / 120x120x25mm
- Scope of Delivery: NF-P14 premium fan / Low-Noise Adaptor (L.N.A.) / Ultra-Low-Noise Adaptor (U.L.N.A.) / NT-H1 high-grade thermal compound / SecuFirm2™ Mounting Kits / Noctua Metal Case-Badge
- Warranty: 6 Years
Fan specifications
- Model: Noctua NF-P14
- Bearing: SSO-Bearing
- Rotational Speed (+/- 10%): 1200 RPM
- Rotational Speed with L.N.A. (+/- 10%): 900 RPM
- Rotational Speed with U.L.N.A. (+/- 10%): 750 RPM
- Airflow: 110,3 m³/h
- Airflow with L.N.A.: 83,7 m³/h
- Airflow with U.L.N.A.: 71,2 m³/h
- Acoustical Noise: 19,6 dB(A)
- Acoustical Noise with L.N.A.: 13,2 dB(A)
- Acoustical Noise with U.L.N.A.: 10,1 dB(A)
- Input Power: 1,2 W
- Voltage Range: 12 V
- MTBF: > 150.000 h
Was £59.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
View the full NOCTUA Range here
BeQuiet Shadow Rock Pro CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £32.99 inc VAT
The decoupled 120mm Shadow Wings PWM fan (SR1) / 135 mm Shadow Wings PWM fan (TopFlow) guarantees the best relationship between cooling effect and audible noise. The wave-shaped contours of cooling fins minimize noise and optimize air flow.
Four heatpipes transport heat via the shortest path to the optimal point within the cooling fins. The Single-Fin layout is a compact means to attain the best heat dissipation from every individual cooling fin whereas the TopFlow cooler layout provides optimal cooling for the CPU as well as for nearby system components. Completely nickel plated heat sink. The stable backplate ensures vibration-secure attachment, even when
- Number of heatpipes: 4
- Dimensions (incl. fan): 122 x 158 x 95 mm
- 1 x Shadow Wind PWM Fan inculded
- Weight (incl. fan): 740 gram
- Fan Dimensions: 120 x 120 x 75mm
- Fan Speed: 1700 RPM
- Noise Levels: 7.8 - 21.4dBA
- Air Flow: 57.2 CFM
- 4 pin PWM connection
- Back Plate Mounting Included
- 3 Year Warranty
Was £36.98 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
View the full Be Quiet Range here
Those are pretty decent price drops. I was hoping to see the black rock pro listed there as well though :P
Edit: I mean dark rock pro lol
