HungOver and not thinking straight
Don
5 Oct 2005
Liverpool
I have this SQL query... dont know what I'm doing wrong would like some help...
public static int GetBookingInsertID()
string connectionString = ConfigurationSettings.AppSettings["ConnectionString"];
System.Data.SqlClient.SqlConnection sqlconnection = new System.Data.SqlClient.SqlConnection(connectionString);
string queryString = "SELECT MAX [book].[PriKey] FROM [book]";
System.Data.SqlClient.SqlCommand sqlcommand = new System.Data.SqlClient.SqlCommand(queryString, sqlconnection);
System.Data.SqlClient.SqlDataAdapter dataAdapter = new System.Data.SqlClient.SqlDataAdapter(sqlcommand);
System.Data.DataSet dataSet = new System.Data.DataSet();
//dataAdapter.Fill(dataSet);
return dataSet.Tables[0].Rows[0].ItemArray[0];
keep getting an error
Thanks,
Stelly
CS0266: Cannot implicitly convert type 'object' to 'int'. An explicit conversion exists (are you missing a cast?)
SELECT MAX([book].[PriKey]) AS max_book FROM [book];
EDIT: See Below! I thought it might have been something wrong with the use of the MAX() function...I was wrong!
dataSet.Tables[0].Rows[0].ItemArray[0] returns an object.
You need to cast this to an int for it to work as your function returns an int type.
Code:
(int)dataSet.Tables[0].Rows[0].ItemArray[0];
Code:
Of course :) Thanks mate... thought I missed something
Stelly
