Hurrah a puncture!
24 Feb 2004
St.Andrews
Yay my second ever puncture and boy am I not happy :(
New tyres all round and less than 4k into the set I have a puncture in the front right. barely an inch from the edge so I'm guessing not repairable :(
I would provide a picture but bluetooth and vista apparently = no way :/
Had a quick ring round and the only place to be able to do the job locally is wanting £150 for the single tyre :( (225/45/R17 Y)
If only they were a little more worn I could have changed both fronts - as it is I'm stuck with sourcing the exact same tyre as I have :/
Just at the start of my holiday as well....
What has made the puncture?
What car is it?
How hard do you drive?
If it's a nail or similar, and it's not an uber high performance car and you don't live on the edge of grip all the time, then Tyreweld it. If your car's FWD then it'll be easy as pie, it WILL last and you pocket £150 until you decide to put 2 new ones on the front and put your good one in the spare. I might get flamed for this but i did it on reccommendation from my tyre place, when i got a punture on my rear tyre on the VFR and it was fine for the rest of the life of the tyre. Admittedly I probably would've needed a few more brave/stupid pills to do if it had been my front tyre.
What tyre? seems a bit pricy for that common size unless its something exotic
Not a run flat :(
Just a regular Michelin Pilot Primacy I needed. Cheapest I found it was £110 plus local fitting. Told several days for delivery so tried etyres....
etyres said they could do it :)
Nothing happenend for nearly 2 days so I rang the fitter to ask what was going on. Fitter told me he didn't cover St.Andrews as he was based in Falkirk (60 miles away and the wrong side of the Forth Estuary)
etyres said they'd try and find someone else - that was thursday night. This morning they said the might be able to get someone to fix things the middle of next week :/
Cancelled that and had to go locally - Only place in town with a Pilot Primacy was looking for £150 :(
Also it was a screw pretty close to the edge of the tyre :( Certainly not repairable.
Tyreweld for a permanent fix, wtf??
If its just a nail then an inch in from the side can be fixed for £10-15
Not exactly - only had 1 puncture before this and it was almost dead centre. Got the picture off my phone now. Place I went to wasn't happy to repair it.
See what you think...
Was a bit slow and only just realised that picture was what he was on about in the op. No way I would be ditching that tyre for that, especially at that cost. :eek:
local tyre fitter quoted me 370 for a pair of dunlops for the lcr 225/40/18's 219 quid fully fitted a pair from black circles
I get charged £180 for a pair of Kumho 245/35/r19 and thats with fitting :confused:
And thats definately a repairable. I know, I've had it done closer to the edge than that before.
That's repairable, easy!
I got a screw in the back tyre of my Fazer, the tyre was about two weeks old so I got it repaired. I commute at about a million miles an hour every day (possible exagguration, but it's a fast litre bike, so it's not delicate to tyres) and it's been absolutely fine, I've done hundreds and hundreds of miles on it with no problems at all, it doesn't let air out any quicker than a non-repaired tyre either. If I can get a repair on the back tyre of my bike, that'll be fine :D
