The ones that can fit about 40 cans?9761 said:Hi,
Just wondering if anyone has one of these fridges? I am thinking about getting one for my bedroom but one thing that concerns me is the noise level as some are rated at 40db and I do plan to sleep LOL
cheers
Meh, its pretty crap really. Its empty half the time.VeNT said:make sure about the room to breath thing, I'm sure you've done it right but you don't want to bugger up your new fridge!
Mic said:Meh, its pretty crap really. Its empty half the time.
140 euro. Its the stella artois one.VeNT said:how much it cost you?
thinking of getting one for my office when I re do it
does it work ok?Mic said:140 euro. Its the stella artois one.
Not likely. The husky has a thermostat which turns off the cooling when needs be. The smaller ones dont, thus they are loud all the time.9761 said:I might go for one of those smaller one, would they be more quieter?
Thats an idea iv been looking at. The only problem is that it takes a couple hours to re-cool everything inside.id10T_error said:Just turn it on when you need it!! I have mine on a cheap electronic timer so that it's not wasting electricity or making any noise for the 7-8 hours I'm asleep.
Also pops the tv a bitkemistry said:ive got the big guiness one. theyre abit noisy when theyre doing the cooling thing but other than that theyre silent. they keep your beer nice and chilled too
one thing i noticed though, having it plugged into the same ring as a hifi isnt a wise choice, as when the cooling thing starts a loud pop came through my speakers which didnt sound too healthy
So if i actually have loads more stuff in it it wont come on as much?Takhisis said:Fridges cool themselves more often if they are half empty/empty - items in the fridge remain colder than air does, so if its full of air, it'll have to work harder to keep at the temperature that its set - same applies to freezers
/useless info
Mic said:So if i actually have loads more stuff in it it wont come on as much?![]()
I high five you good sir.
