Hi,
New here been reading for a while. Currently have....
AMD Athlon 3700+ @2.6ghz
Asus A8N SLI Deluxe
BFG 7900GT OC 256mb
2GB RAM
OCZ 500w PSU (main connector is 20pin+4pin)
SATA HDD's
IDE DVD-RW
Win 7 64bit.
As im sure you will agree its time for an upgrade lol.
Ive come up with this so far.
AMD Phenom II X6 1075T
Gigabyte GA-970A-UD3
8GB (2x4GB) Corsair DDR3 XMS3, PC3-10600 (1333) 9-9-9-24, 1.50V
£245.
GFX i litteraly have no idea.
I know ill need a SATA DVD, what about my PSU as i see most new mobo's are 24+8? I did google it and it seem you can position the connectors to get it work.
Ill be using my old case and HDD for the time being.
Is everything compatable or would you reccomend something different?
I use my PC for general stuff, will want to watch 1080p on it. I appreciate the 2500k is the one to have at the minute but for the £80 extra i wont notice the difference.
Thanks,
Sean
Asus A8N SLI Deluxe
BFG 7900GT OC 256mb
2GB RAM
SATA HDD's
IDE DVD-RW
Win 7 64bit.
£245.
Thanks,
Sean
