HWMonitor reading 127c
Caporegime
27 Nov 2005
Guernsey
Does anyone know if these 118c & 127c readings are just an error with the HWmonitor software
This is with my system just at idle with no loads
127 is suspicious as that’s possibly the limit of what the sensor/software could report if it’s using 8-bit signed integers. Not an expert (someone please educate me more if you know).
This would suggest an error or no connection etc. If components were hitting that you’d probably notice other issues with the machine anyway and it’s be unlikely to manifest at idle.
I had a similar reading on an ASRock board. As others have said it is a sensor that does not exist hence the alarmingly high temp reading. Safe to ignore.
