Hi...
I just bought a nice new HX850 Gold & the voltages are great & I can't fault it for that...
My issues is with the 140mm fan & the controller, when playing games & using the GPU or under small load, the fan is so loud I can hear it over my headphones, its like its running at 100% even thought the system load is not that high for the PSU to manage ?
No overclock on CPU or GPU & stock cooler on due to my H100 being RMA. HDD unplugged, just running Mobo (inc Ram & CPU), GPU, Fans, 2 USB & 2 PCI-E devices).
I've tried turning the PSU over so the fan is facing up & that just made it louder, I have a 200mm fan on the side of my TT level 10 GT that I can face the fins to the top of the PSU so it can be cooled even more but its the same & what seem to be running 100% speed ?
The noise is louder that anything else within the system, even over the three 200mm fan on MAX !
Now, is this a fault with this PSU & a new one would fix it or are they all the same ?
This is the same noise level... http://www.youtube.com/watch?v=cM2ix8wDM9c
