HX850i 850W '80 Plus Platinum Digital Modular Power Supply
11 Jul 2003
Telford//west mids
Anybody got one of these as I'm after a new psu for my build,are there any problem with it the reason I ask is I have a full set of corsair grey cable kit.
Nope they work fantastic, until recently had HXi series in 1000w and 1200w until I need to move up for more capacity. Very quiet fluid dynamic bearing fan which rarely runs and solid specs. Usually though most people will opt for the RMi / or new HX units as they are even slightly better on things like ripple thanks to capacitors in the cables (just lacks link for the HX), or other options are available for similar specs but cheaper when cables are not a consideration. But performance wise worked flawlessly for me.
