Hydro H80 & Silverstone TJ08B-E
30 Oct 2007
Stubbington
Hi,
Would be interested here hear if anyone has fitted the H80 into the TJ08-E? Did it fit OK? Looks like it could be tight as it can only go onto the back fan grill.
Thanks in advance.
Hi,
Thanks in advance.
This is a quote from the owners club
http://www.overclock.net/t/1068487/silverstone-tj08-e-owners-club
Confirmed Coolers:
- Intel Stock Cooler
- Corsair H70
- Corsair H60
- Corsair H50
- Noctua C14
- Corsair H80
- Antec 620
- Antec 920
- Tuniq Tower
- Thermaltake Silver Arrow
- Noctua D14
- Noctua U9B SE2
- Be Quiet! Dark Rock Pro
Just to give you a tip when fitting the H80, due to the space limitation you will have to install the pump/block first then the rad and rear fan first and then you have to add the front fan.
OK thanks for the tip.
So be to clear, does the complete rad & two fans still fit inside the case? or due to space does the rear fan need to be fixed to the outside?
Regards
