Hydro H90 compatible case?
27 Dec 2012
Just purchased a Hydro H90, but it apparently uses a 140mm fan compared to the usual 120mm.
any recommendation on a case for it?
Lots of cases support 140mm somewhere on the case.
Just pick which ever case you like the look of with 140mm mounts in the rear/roof or wherever you want to put it.
My personally suggestion would be the fractal design arc midi R2 (rear 140mm) available very soon (this month), but its mostly down to personal preference most the time as most the cases available are excellent in there own merit.
yes but a lot of them only support 120mm fans, I have been through the ocuk selection and on the majority of them I see no mention of 140mm fan support
Yeh, a lot of cases still only support 120mm, but a lot support 140mm as-well.
Fractal Design cases
Some corsair cases
Some Zalmans
Some Antec
Some Coolmaster
Plenty to choose from.
