Basically as the thread title goes, can you fit an Alpenföhn Föhn 120 Wing Boost fan onto the Hyper 212+? the Hyper comes with standard clip fan holders, but as the Alpenfohn's were opened cornered I wondered if they'd be a problem. Many thanks!
One method ive used in the past was cable ties, (closed corner fans wouldnt fit on the TRUE i had). Thread a cable tie through the fan screw holes, then through the cooler fins, take a second tie and thread it onto the first, tighten up and trim the excess. A very secure method as well.
