Hyper-V
18 Oct 2011
Hi, thinking about making a virtual desktop but just wondering do i have to install a gpu driver and visual c++ etc again?
Configuring the operating system of a virtual machine is essentially the same as setting up that of a physical computer. If the software you're going to be installing needs a visual c++ redistribution installed then you'll need to install it in the VM as you normally would.
The drivers you install will be different - you'll need to install the Hyper-V Integration Services once you've completed the base OS install which will then configure the VMs drivers.
Right ok, is the "Hyper-V Integration Services" an option in the VM i check to install or do i have to download it from another source?
Integration services don't need to be installed for server 2016 or Windows 10, link. The features are enabled on the host and guest VM.
Have the VM up and running with an internet connection but it feels laggy, maybe hyper-v is not what i am looking for since i am trying to run low demaniding games on it (dual log).
What games? It needs CPU cycles to drive graphics so it's never going to work well.
