Hyper z600 CPU Cooler
6 Sep 2008
Near Hull
http://www.coolermaster.com/products/product.php?language=en&act=detail&tbcate=1&id=4509
this CPU cooler doesn't come with fans attached to the outside of it, but as you can see in the picture you can get fans to attach to the outside of it.
2 questions:
would the fans be easy to attach to the CPU cooler?
would this cooler(with the fans) provide good cooling on an AMD athlon 6400+ 3.2ghz?
thankyou.
Sooner get a Black True tbh, comes with two clips for a push-pull configuration.
TRUE black comes with two sets of clips for push pull.. tbh would buy a normal TRUE and use cable ties :) it will outperform the coolmaster easily if you are using fans rather than running passive
