Hyperlink Moves Down to Next Line? HELP!
30 Nov 2005
London
Dear all,
When I insert a hyperlink into my website it moves down a line.
I don't want it to move to its own line but be on the same level as the text.
I have looked and there are no break, or paragraph tags.
What could it be?
Everytime I insert a hyperlink it goes to its own line.
Please help.
Thanks
Are there any styles being applied to your hyperlinks which are causing them to be on a new line?
Are they in a small div so they wrap to the next line?
Can you post some samples?
Post either a link to your site or your HTML and CSS. Anything else is just stabbing in the dark; for all we know, you could have a
Code:
a { display:block; }
somewhere, or you might be using anchor tags inappropriately. We never know.
