Hyperlink to Excel
From Here
1. Start Windows Explorer (Start, Run, Explorer).
2. From the Tools menu, select Folder Options.
3. Select the File Types tab.
4. Select the file type that you don't want to open in IE and click Advanced.
5. Clear the "Browse in same window" check box and click OK.
6. Close the Folder Options dialog box.
