If the hyperloop went from 0 to 107 miles an hour and back to 0 again in 500 metres, what would be the acceleration rate, 0-60 time?
Can someone work it out?
Presumably it envoles s =ut +1/2 at squared??
There's not enough information to calculate it, unless you make assumptions such as the acceleration and deceleration being constant and the same which is highly unlikely.
They could be though, it'll give a rough idea.
I agree, much more likely a higher initial acceleration and longer coast stage. My calculation is effectively the minimum acceleration you could achieve it with but no the most likely.There's not enough information to calculate it, unless you make assumptions such as the acceleration and deceleration being constant and the same which is highly unlikely.
Accelerating from zero to 23.93m/s over 10.45 seconds with constant acceleration would require a rate of 2.28m/s^2
without any of the risks of being in a vacuum
Surely that should be 47.83m/s not 23.93m/s otherwise agree with your method.
How are they addressing the whole implosion problem ?
I have to say I'm disappointed by the progress of this whole project tbh, a conventional motorbike does 400mph in normal air density without any of the risks of being in a vacuum or requiring massive infrastructure etc.
