Stelly said:In 2000 disable
In XP enable
Stelly
its like having an extra 20% of a CPU
Stelly
PinkFloyd said:Yeh no reason why it should be disabled in win2k.....
used to run my dualcore without problems on win2k, so its nothing to do with how it handles multiple threads.....
mmj_uk said:Win2k sees the hyperthreaded CPU as a physical CPU rather than a logical one, hence in many cases performance is actually slower than if you were to just disable HT altogether.
Win2k just isn't optimized for hyperthreading unlike XP so you're better off disabling it.
BillytheImpaler said:I've never seen it cause problems for me. In some database intensive hosting situations I've seen HT cause a performance hit but never in desktop work.
Basically XP knows the difference between a hyperthreading, dual-core and multi-processor and can act accordingly.Stelly said:I have alwasy been told that its different with XP (dont know how)
