i already have the Blu, but am looking to add another two modules.
is there any difference between these two modules? as there is an offer on with OCUK where the genesis grey is as cheap as the standard hyper x blu, and i think it will look good with blue and grey, and i do want 16GB for a future proof PC.
will they work perfectly together? are they basically the same module with different heat spreaders? and will they support auto over clocking with both installed?
links to Memory in question;
http://www.kingston.com/datasheets/KHX1600C9D3B1K2_8GX.pdf
http://www.kingston.com/datasheets/KHX1600C9D3X2K2_8GX.pdf
cheers!
cheers!
