HyperX Cloud Alpha
20 Oct 2004
Nottingham
Hello OCUK sound people.
I Bought this headset on the afternoon of the 25th October, by 21:00 the same day, I'm my second pair (they are going back in the morning).
The headset sound and comfort is really good but the level of crosstalk is unbelievable. Using discord with friends is impossible as they can hear every sound my pc is making and there is nothing I can do. Even muting and physically disconnecting the mic from the headset makes no difference, only disconnecting the mic cable from the sound card stops it.
"listen to this device" is unchecked in windows and i've made sure stereo mix is disabled, changing these settings makes no difference. is this just a 2No. faulty pairs or am I likely to experience the same issue if I replace them again?
Would replacing the cables with better quality cables help with this as it seems like the audio channel is bleeding into the mic channel via the cable.
Pretty gutted because they were comfortable but they are unusable. Anyone with a set offer any insight?
