HyperX Cloud II Terrible Sound Quality using USB sound board?
6 May 2016
So I got a set of these as a present, and the sound quality is amazing ONLY if you do not use the usb sound board. Problem is no one seems to have the issues I do, it sounds tinny and the bass is awful.
I've got the hyper x audio driver installer and my motherboards high definition audio bus's.
But I don't know how to fix it, I can get a converter thing (which the sound board usb basically is) but I'd much prefer to fix the issue I've tried going through my motherboards driver but nothing seems to work...
I have, my set were already on the latest firmware but I reinstaled it anyway, still no fix. Perhaps I'm missing an audio driver, I have the HyperX one and typical motherboard ones but I use to have Nvidia HD Audio. Would the usb sound card override software drivers?
mine sounds great so it must be something you are missing, have you got it set to the highest quality in the which is 2 channel 16 bit 48000khz.
only problem ive every had is the mic is quiet in skype etc... but managed to fix this using an external prgram to run the mic through.
