Say you had a 1080P monitor or 1440P monitor.
You had two GTX680 in SLI.
Would you sell them for a single R9 290 with effectively zero cost to yourself, would you do it?
P.S yes for gaming.
This thread feels like entrapment...
I'd be very tempted to switch them yes.
I suspect in most scenarios the 680 SLI will perform better, but a single 290 will probably be good enough for those either of those resolutions. It's also newer and you'd get TrueAudio, plus Mantle (although with DX12 that may or may not be such a big benefit long term).
There is, at least in theory, the option to go Crossfire later on (although by that time it might be worth considering an upgrade again).
I'm sure there's also a potential saving power wise, but probably not enough to affect the decision.
2*680's for a single 290.... Maybe but it will be a loss of frames in games but not detremental to gameplay.
Yes Crossfire is a possibility later on as the PSU is a HX850.
Hypothetically speaking of course.
Hypothetically, i would not bother as i feel you would notice no difference between 2 x 680's and any single card, be that a 290 or a 780.
Hypothetically though if you want to get a 290 then do so![]()
Depends how long you wait for crossfire of course. There may not be a compatible card available or by that time there may be something newer out and it might make more sense to sell one card and buy another rather than add a second (what will be) older card.
Depending on the cooling solution of both your cards and the 290 it may be quieter going to 1 card too (although with the 290s...).
The extra VRAM may also help at 1440p and even at 1080p with Mantle and its extra VRAM usage.
I will say that I've gone from Palit 570s and EVGA 670s to HIS 7950s and Sapphire 290s and to me the AMD cards 'felt' cheaper. I also, personally, prefer Nvidias driver package and control centre stuff more, but that may just be familiarity.
Let's see if LtMatt agrees with that!![]()
Non-Reference 290: Yes. Reference 290: No.
Depends, if its high refresh 1080 I'd stick with the 680's otherwise single 290 all the way.
I've used both amd and nvidia driver packages etc... A fair bit over the last year, the main thing I notice with nvidia over amd is the very little after driver tweaking that needs done, I found radeon pro essential to get the best from some games with amd, while on the green side its pretty much just plug and play.
Not to say having to use radeon pro is a bad thing, it offers plenty outside of fixing things, just that nvidias package is a little more fool proof for the average user![]()
As I said, I can only speak from what I've used, iirc last driver I used was ~13.7. The fixes I needed to make were never about smoothness or IQ, I was (if you'll remember) one of the people who said 'what stutter?' when the frame pacing thing came about, it was never something that bothered me. Fixes were more around getting crossfire to play nicely either due to buggy (or non-existent) drivers or buggy game patches. Was no bother for me as I actually enjoyed fiddling with things to get the best from them, just perhaps not the best for you average plug a card in and play type user.
If that's all changed in the last 8-9 months then good stuff as it was my one and only gripe with AMD drivers - having to use a 3rd party tool to get the functionality I required![]()
