- 5 Dec 2010
- deep space nine
So. I want to run a bunch of guest VM's using Win 10 OS (host also win 10) ideally want to be as smooth as possible.
I have just started using VMware workstation pro after using virtual box (where I used lubuntu) and am assigning 2 cores per VM with one virtual core per physical core ( I have no idea if these are optimal settings) Win 10 runs pretty well here but at that core assignment will it run into problems the more VMs I run concurrently? I can run three at moment and host and that seems to be fine.
I currently run a 4790k non-OC with 32GB ram. I assign 4GB per VM. I saw these articles and it got me thinking whether I would be better changing my set up:
https://www.google.co.uk/amp/www.techspot.com/amp/review/1218-affordable-40-thread-xeon-monster-pc/
https://www.google.co.uk/amp/www.techspot.com/amp/review/1155-affordable-dual-xeon-pc/
Any thoughts on the two builds ? Or alternate suggestions ?
