Hyte Y40 or Y60 for a 4090 FE build
30 Oct 2011
Loughborough
Hi Guys, Just about to click buy however having doubts about which case to go for. Initially the Y40 looked beast for the 4090 with better airflow (card being slightly further set back) however now thinking the improved cable management and more room in the Y60 might be the way to go? What are peoples thoughts????
I just wanted to update since I finally finished it - I went with the Y40 in the end as I liked the more compact builds looking on Youtube- very happy with the build quality of the case although cable mangement is not great at the back - which I may redo it later on! All done for now and this is literally my favourite thing which I dont get to play on enought :) Although I will be upgrading the AM5 chip in a few years but this will last me a while!
Nearly everything was from Overclockers - the next thing on the list is to look at a new monitor!
ItemCost
HYTE Y40 Mid-Tower ATX Case - White
£116.66​
Strix B650-A Gaming WiFi AMD Socket AM5 Motherboard
£237.82​
AMD Ryzen 5 7600X Six Core 5.30GHz (Socket AM5)
£207.49​
ASUS ROG Ryuo III 240 White Performance AIO CPU Liquid Cooler with OLED Display - 240mm
£208.29​
Kingston FURY Beast EXPO RGB 32GB (2x16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit
£99.99​
Nvidia GTX 4090 FE
£1,599.00​
Lian-Li UNI AL120 Addressable RGB White 120mm Fan Triple Pack with Controller
£62.49​
Phanteks Extension Cable Combo Kit - White
£19.16​
Crucial P5P 1TB M.2 2280 PCI-e 4.0 x4 3D NAND NVMe Solid State Drive
£74.99​
Kingston KC3000 PCIe 4.0 NVMe M.2 SSD
£90.97​
Jedi Survivor code (stiil broken but pretty in places tbh!)
£0.00​
Total
£2,716.​
