Hyte Y40 release date and component recommendations for first time hardline ATX build.
18 Jan 2023
crewe
Hi guys, I have just put in my order for a the new Hyte Y40 as it looks really cool. when i get it ill be upgrading from a Mini ITX (Dan A4 clone) to it. Ill be moving all my stuff to the new case including the mini ITX mother board. Some things ill be upgrading will be the PUS to an ATX one (cables are too short on current one) and ill be upgrading the AIO form a 92mm AIO to a custom Hard line. Is there anything you think that will make the case look nicer, ive also gotten a few random bits and bobs to help with the quality of life improvements.
Water cooling
XH305i RGB Pro White CPU hard tube water cooling kit
Bykski Bending Tool Spiral B-STC-s 14mm
Case upgrades
right angle 24 pin ATX plug (makes the cables run smoother)
Focus GX 1000 White ATX (no need for sleeved cables as they are white)
180 degree angled 8 pin GPU plug (to hide the cable bend)
Header 19 pin to Type E + 19pin mother board. (basically internal board turning motherboards usb 3.0 header into a usb 3.0 header and usb c internal header as my mother board doesn't have one (usb c header)
2 QA140 RBG white corsair fans to match the water cooling ones. (future 2nd radiator fans but will be used as air intake fans for the time being)
Does anyone have any other PC components they would recommend. Like just random but useful ones that people wont notice but if you look close it make you go 'Ah that's a good idea wish i thought of that'.
Anyone know when the Hyte Y40 will be released?
