hyundai B90A, B91A, L90D+ - whats the difference?
13 Sep 2003
Doncaster
Still waiting on Hyundai to replace a DOA Imagequest B91A. If it goes on for much longer, there might be the possibility of getting an alternative model instead. So i was wondering what the difference was between the those three models? (thread title). The specs appear to be the same.
joe
they all use the same panel (8ms TN Film panel from Samsung) and only the features, looks and price vary really.
B90A and B91A are the same unit, just the B91A is black, whereas the B90A is silver. These are both Analogue Monitors and do NOT have speakers
L90D+ is a digital Monitor (use your DVI port if you have one) and is multimedia so has speakers. It also has ImageTune software which has some really neat features including a very clever securty setting which locks into your PC's BIOS rendering the unit useless if stolen. (password protected so you can change it if you change your computer).
No worries, you were going to get me the log number that Repairtech would have issued you so I could chase it up internally..
A good contact at repairtech is Lauren. She is senior so ask to speak to her.
thanks Insider. I just assumed that as they basically still didnt have that model back in stock yet, there would be nothing you could have done anyway. Whoever it was i spoke to on thursday said they had the bulk of deliveries on fridays, and reckoned it should come in on that. She also told me to ring today (will be doing tomorrow), to give it time to show on their system. I'll make sure i ask for Lauren tommorrow.
fingers crossed.
