hyundai hm22w
7 Mar 2005
The Voice Of Football
Has anyone any experience of the above monitor/lcd tv combo?
Am after a cheap ps3/tv/monitor solution and it seems the above fits the bill if I connect a freeview box to it via scart.
Alternatively, does anyone have any other suggestions?
Nobody?
The spec appears really good and coupled with a freeview box it could be a bargain! Or am I missing a trick on the spec?
Television Picture Features
Visible Diagonal 22"
Resolution: 1680 x 1050
Aspect Ratio: 16:10
Display Colour: 16.7 million
Brightness: 300 cd/m2
Contrast Ratio: 1000:1
Viewing Angle: 160/160
Response Times: 5ms
TV System: PAL/SECAM
Connectivity
Composite CVBS x 1
Scart x 1
Digital x 1 (HDMI)
TV Tuner x 1 (analog)
VGA x 1 (D-SUB)
Audio x 1 (L/R)
PC Audio x 1
Sound Features
2.5W x 2ch
Additional Features
Input Voltage: 100-240V
Consumption: <55W
Dimensions: With Stand: 518.4 x 430.4 x 216 mm
Weight: 8.0kg
AC Power Cable
Remote Control
Batteries
User Guide
15pin D-Sub Cable
PC Audio IN Cable
OSD Function: YES
Teletext: 10 Pages
IR Remote Control: YES
Well I am 99% certain I am going to take the plunge on this.
The nearest competitors are the LG and Samsung equivalents, which are both £100 more.
Any other advice before I hit 'buy' ? :)
The contrast ratio isn't amazing, but I have no experience with this monitor. I'm actually looking at the LG M228WD 22" which as you say is £100 more. However I think that there has to be some catch with the monitor you've looked at. It's so cheap for what it offers.
I know...It does seem too good to be true. But if it's rubbish then I guess I can fire it back under distance selling.
It lacks the digital tuner of the samsung and LG models but that's nothing a freeview/sky + box can't sort.
