Hyundai L90D+
2 Mar 2004
Shropshire
Hi guys,
I've had the above monitor for a while now and can't really complain. I do however have one gripe about it and that is it will only support up to 1280 x 1024 resolution and I would have thought a 19" monitor would have been able to easily support above that.
Are they are programs that I can use to force it, or enable it or am I stuck with it, as I'd really like to increase it, instead of using my 19" CRT which supports 1600 without any fuss.
Thanks
you won't be able to go above that since the panel itself has a native resolution of only 1280 x1024 based on the number of pixels which make up the matrix. You'd need a 20" model for a 1600 x 1200 res
