Hyundai Q261 26'' LCD TV Monitor
28 Feb 2006
Newcastle
Hi,
Just wondering how good this LCD TV screen is ?
It has great specs:
- HD Ready
- 66 cm (26“) screen diagonal
- 16:9 aspect ratio
- 8ms response time
- 1366 x 768 Pixel native resolution
- 1000:1 contrast ratio
- 500 cd/m² luminance
- 170° (h./v) viewing angle
- 2 integrated TV Tuner (analog + DVB-T)
- DVI Input (HDCP)
- SRS TruSurround XT™
- FiT Engine™ Picture optimizing processor
- 250 pages teletext
- Picture-in-Picture function, Electronical Program Guide (EPG)
But was wondering what the major let downs are. I can see that the resolution is at 1366x768 where the new gfx cards can play screen res of upto 2566 (or something), so maybe a higher res screen?
Just need a little help why its not such a big thing with this screen in the forums.
Cheers
Its 26" and not 32 or 37?
Depends on your planned usage, how for you sit from it.
Most people are put of by resolution. I am blind enough it doesn't matter, just don't have the money or I would tell you.
One thing that would be weird is using word and excel with such big letters, but i guess you would get used to it
Games and movies would dominate on a screen like this though.
You might also want to peruse the Home Cinema & HiFi forum as there is a lot of TV chat in there...the Hyundai is ultimately a TV.
It does have a component input it says so on the hyundai website.
26 inch TFT-LCD TV
- Integrated Digital Tuner (PAL, DVB-T Dual Tuners)
- HD ready
- FiT EngineTM (Fine Imaging Technology)
- WXGA+(1366x768) HDTV Resolution
- Brightness : 500 cd/m2
- Contrast Ratio 1000:1
- 170°(H)/170°(V) Viewing Angle
- 8ms Fast Response Time
- 10Wx2ch Detachable Speakers
- SRS TruSurround XTTM
- DVI-HDCP input / Dual Scan / PIP / EPG
Display Visible Diagonal 26"
Display Area (mm/Inch ) 575.77(H)X323.71(V)mm
/ 22.67"(H) x 12.74"(V)
Aspect Ratio 16:9
Display colors 16.7M
Resolution 1366X768
Brightness (cd/m2) 500(typ)
Viewing Angle (H°/V°) 170° / 170° (typ. CR:10)
Response Time (ms) 8(typ,Gray to Gray)
Lamp Life Time 50000Hr(Min)
TV Function Analog Tuner 1(PAL)
TV System NTSCPAL B/G, D/K, I,SECAM B/G, L
RF Signal VHF,UHF,CATV
Digital Tuner Built In Digital Tuner (DVB-T)
TV System COFDM
Color system Auto(PAL/SECAM)
Picture Progressive Scan Yes
Color Tone Control Yes
FiT Engine™ Yes
Deinterlacer Yes
Display Capability (DTV Ready) 576i,576p,720p,1080i
Picture Mode Standard, Dynamic, Movie, Mild, User
Film mode detection Yes
Noise Reduction Yes
Variable Aspect Ratio Auto, 4:3, Zomm1~2, 14:9, Wide
Color temperature Standard, Cool, Warm
Multiple Screen PIP, Double Window
Sound System Power Output (RMS) MAX 10W x 2ch
Speakers Detachable
Sound Mode NICAM/A2 stereo
Sound Enhancement SRS TruSurround XT
Sound Equalizer User,Standard,Music,News,Movie
Sub Woofer out Volume, Frequency control
AVL Yes
Function General Memory (Multi Memorycard Playback) No
Sleep Yes
Timer Yes
Picture Still Yes
Key Lock Yes
Scart Auto Detect at RF input Yes
Teletext 252 pages
Parental Lock Yes (DVB-T)
Digital EPG(Electornic Program Guide) Yes
Terminals Input Antenna (RF) 1
PC Analog input (RGB, D-Sub) 1
DVI 1 (with HDCP)
Composite 1
S-Video 1
Component (Y/Pb/Pr) 2
PC Audio Yes
RS232C Digital 1
HDMI-HDCP Interface TBD
SCART
(AV Signal in/out) Full 1, Half 1
Output Earphone Yes (Auto Detection)
Audio Out Yes
Composite (AV) 1
Composite Audio AL, AR (RCA)
Subwoofer Output Yes
Digital Audio Output(SPDIF) Dolby AC-3 bitstream out
PCM out
External Speaker Out Yes
OSD Languages Eng/Ger/Fra/Neth/Spain/Italy/Fin
Power Input Voltage 100 ~ 240V
Consumption On/Working 120W
Stand By 3W(Typical)
Mecanical
Features Tilt angle (Down~Up) 0~15°
Kensington lock Yes
VESA Mounting hole 100 x 100
Dimension
(mm/Inch) Set (W x D x H), without Stand 640.0 x 101.0 x 389.0 /
25.2" x 3.97"x 15.3"
Set (W x D x H), with Stand 640.0 x 230.0 x 485.0 /
25.2" x 9.05" x 19.09"
Packed (W x D x H) 737.0 x 297.0 x 582.0 /
29.02" x 11.69" x 22.91"
Weight
(kg/lbs) Set, without Stand 13.5 Kg / 29.76 lbs
Set, with Stand 17.5 Kg / 38.58 lbs
Packed 21.3 Kg / 46.96 lbs
Accessories AC Power Cable, Antenna(RF) Cable, Universal Remote Control Unit, User's Guide
http://www.overclockers.co.uk/acatalog/lcdtv26p.html
