I am a idiot so please help me...
1 Sep 2005
wonder if someone could help me.
I purchase this memory
http://www.overclockers.co.uk/showpr...=8&subcat=1517
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) [F3-12800CL8D-4GBRM ]
I have 2 blue ram slot next to each other and 2 black ones next to each other. On my p4 if i wanted dual i had to install 1 in 1 blue and 1 in the corresponding black. When i do that with this, it shows up as single channel and with a timing of 9-9-9-24. When i install the 2 sticks in the 2 blue slots (right next to each other) it finds it as dual but timings are 8-8-8-24 so im a bit confused. Can anyone help, had a look on some sites but no idea!
cheers
cheers Philly for your reply, i take it that it has changed sonce my last build (6+ years) when you needed to skip a slot so to speak.
They are now both on the blue slot (no slot in between) and OC to 800Mhz running at 11-11-11-29
EDIT: are these timings not high for this spec of ram?
well the spec on the ocuk page say 8-8-8-24 at 1600mhz, so i would assume something is up there, could you change them manually and see if they will boot/work?
