i am a noob at watercooling :)
6 Oct 2011
Malta
as u see from the title of this i am new to water cooling. i want to water cool my i7 2700k at 4.8Ghz i was wondering if anyone could spec me some parts or tell me if this kit is good enough (since only 1200mm): http://www.overclockers.co.uk/showproduct.php?prodid=WC-040-OE
. if possible i would not like to spend more than 130 . also if anyone needs to know the case if HAF X
thanks
120 isn't going to do it mate
If you're not ready (money wose) to go for a full loop, then don't bother - stick to air.
Do it properly if you do it :)
Ideally, you'd be spending £300ish. The HAF X can easily take a 360 rad up the top so use it to its full potential.
For you, i'd recommend the noctua DH14
Like Cleeecoo said, with £130 stick to the air cooling. It will cost less and probably it will be more efficient than any of this closed loops. I did have H70 and wasn't really happy with it. Now I'm going to do custom loop.
ok so i am thinking to go as you said full loop for about 300 or maybe a bit less what will you recommend . if i choose the parts im sure they wont be compatible :P i would much appreciate it if someone gives me a list of everything i will need .
thanks
