I am looking for...
19 Oct 2009
Berkshire, UK
A quiet case that is less than 400mm tall, no wider than a standard tower would be, and ideally can be fitted with an ATX motherboard.
If I cannot find a good enough option, then I will just make other arrangements, but I thought I would ask first, so any suggestions?
Been looking and found one which is 411mm tall.
Areocool Dead Silence Cube.
Ohhh looking closer it only takes miniATX or microATX.
Will keep looking about
Yeah, it's very tricky, thanks very much for trying though.
That case does look alright, yeah.
I think I will need to reconsider my location of the system, oh well.
Cheers!
Lian Li PC-C32B says it's 426mm, if you turn it on its side. Not seeing anything else in the case section that's close while still being ATX though.
