i am new to building pc's
7 Jul 2008
i am new to building pc's is it possible to build a reasonlbe tower for about £350 that will run wow and couple other MMO maybe stargate worlds when it comes out
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail
Asus M3N78-VM NVIDIA 8200 (Socket AM2+) PCI-Express DDR2 Motherboard
Asus ATI Radeon HD 4670 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
OCZ StealthXStream 500w Silent ATX2 Power Supply
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM (HD322HJ)
Kingston HyperX 4GB (2 X 2GB) DDR2 8500C5 1066MHz Dual Channel Kit
Coolermaster Elite 335 Case - Black (No PSU)
Samsung SH-S223F/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black)
Total:£411
Personally, i would pay a bit more and get a better motherboard. With about £17 more you also get a much better graphics card.
Edit: For OS use Win 7 Beta, its free
The processor i listed is pretty god, and can be overclocked a lot too if you ever want to do that.
Graphics is a bit weak, which is why i suggest spending more to get something better. For WoW its more than enough really, and if you just want to play without too much care about max settings then it should do you i think.
Mobo again is not top quality, you would need to check that the stock bios supports the CPU too, best way is to call OCUK directly and ask them.
Really, at these price points you cant get something much better though. its all about the budget.
