- 30 Aug 2009
- one nation under sony
Code:
using System;
using System.Collections.Generic;
using System.Linq;
using Microsoft.Xna.Framework;
using Microsoft.Xna.Framework.Audio;
using Microsoft.Xna.Framework.Content;
using Microsoft.Xna.Framework.GamerServices;
using Microsoft.Xna.Framework.Graphics;
using Microsoft.Xna.Framework.Input;
using Microsoft.Xna.Framework.Media;
namespace cw
/// <summary>
/// This is the main type for your game
/// </summary>
public class Game1 : Microsoft.Xna.Framework.Game
GraphicsDeviceManager graphics;
SpriteBatch spriteBatch;
const int WINDOW_WIDTH = 400;
const int WINDOW_HEIGHT = 400;
Texture2D paddle;
Rectangle paddleRect;
Texture2D ball;
Rectangle ballRect;
HUD hud;
int paddleshift = 10;
const int Lives = 3;
int START_SPEED = 5;
Random rand = new Random();
double randHolder;
Vector2 velocity = new Vector2(1,1);
double angle;
public Game1()
graphics = new GraphicsDeviceManager(this);
Content.RootDirectory = "Content";
graphics.PreferredBackBufferWidth = WINDOW_WIDTH;
graphics.PreferredBackBufferWidth = WINDOW_HEIGHT;
IsMouseVisible = true;
/// <summary>
/// Allows the game to perform any initialization it needs to before starting to run.
/// This is where it can query for any required services and load any non-graphic
/// related content. Calling base.Initialize will enumerate through any components
/// and initialize them as well.
/// </summary>
protected override void Initialize()
// TODO: Add your initialization logic here
/// <summary>
/// LoadContent will be called once per game and is the place to load
/// all of your content.
/// </summary>
protected override void LoadContent()
// Create a new SpriteBatch, which can be used to draw textures.
spriteBatch = new SpriteBatch(GraphicsDevice);
Texture2D paddle = Content.Load<Texture2D>("Paddle");
Rectangle paddleRect = new Rectangle(WINDOW_WIDTH / 2 - paddle.Width / 2, WINDOW_HEIGHT - paddle.Height, paddle.Width, paddle.Height);
Texture2D ball = Content.Load<Texture2D>("ball2");
Rectangle ballRect = new Rectangle(WINDOW_WIDTH / 2 - ball.Width / 2, WINDOW_HEIGHT / 2 - ball.Width / 2, ball.Width, ball.Height);
angle = 2 * Math.PI * 30.0 / 360;
velocity.X = (float)(Math.Cos(angle) * START_SPEED);
velocity.Y = (float)(-1 * Math.Sin(angle) * START_SPEED);
hud = new HUD();
hud.Font = Content.Load<SpriteFont>("Arial");
// TODO: use this.Content to load your game content here
/// <summary>
/// UnloadContent will be called once per game and is the place to unload
/// all content.
/// </summary>
protected override void UnloadContent()
// TODO: Unload any non ContentManager content here
/// <summary>
/// Allows the game to run logic such as updating the world,
/// checking for collisions, gathering input, and playing audio.
/// </summary>
/// <param name="gameTime">Provides a snapshot of timing values.</param>
protected override void Update(GameTime gameTime)
if (GamePad.GetState(PlayerIndex.One).Buttons.Back == ButtonState.Pressed)
this.Exit();
do
randHolder = rand.NextDouble();
while (randHolder < 30.0 / 360 || (randHolder > 60.0 / 360 && randHolder < 120.0 / 360) || randHolder > 150.0 / 360);
// TODO: Add your update logic here
if (Keyboard.GetState().IsKeyDown(Keys.Left))
if (paddleRect.Left > 0)
paddleRect.X -= paddleshift;
if (Keyboard.GetState().IsKeyDown(Keys.Right))
if (paddleRect.Right < WINDOW_WIDTH)
paddleRect.X += paddleshift;
ballRect.X += (int)velocity.X;
ballRect.Y += (int)velocity.Y;
if (ballRect.Y < 0)
ballRect.Y = 0;
velocity.Y *= -1;
if (ballRect.X < 0)
ballRect.X = 0;
velocity.X *= -1;
if (ballRect.Y > WINDOW_HEIGHT - ball.Height)
ballRect.Y = 0;
velocity.Y *= -1;
hud.Lives -= 1;
START_SPEED = 5;
velocity.X *= 0.9f;
velocity.Y *= 0.9f;
if (hud.Lives <= -3)
velocity.X *= 0f;
velocity.Y *= 0f;
if (ballRect.Right > WINDOW_WIDTH)
ballRect.X = WINDOW_WIDTH - ballRect.Width;
velocity.X *= -1;
if (paddleRect.Intersects(ballRect))
ballRect.Y = WINDOW_HEIGHT - ballRect.Height - paddleRect.Height;
velocity.Y *= -1;
velocity.X *= 1.10f;
velocity.Y *= 1.10f;
hud.Score += 10;
//paddleShift = (int)(paddleShift * 1.15);
if (Keyboard.GetState().IsKeyDown(Keys.Down))
LoadContent();
/// <summary>
/// This is called when the game should draw itself.
/// </summary>
protected override void Draw(GameTime gameTime)
GraphicsDevice.Clear(Color.DarkSeaGreen);
// TODO: Add your drawing code here
spriteBatch.Begin();
spriteBatch.Draw(paddle, paddleRect, Color.White);
spriteBatch.Draw(ball, ballRect, Color.White);
hud.Draw(spriteBatch);
spriteBatch.End();
base.Draw(gameTime);
it worked before then I tried to add a intro screen didn't work took the code out and now the game won't work
