I cant access nVidia control panel.
20 Oct 2010
Scotland, My home.
As title says i cant access the control panel. It will either crash on load or it will load and only display "stereoscopic 3d". I have tried going back drivers and i have tried the CD drivers i got with my 460gtx...
Anyone got any ideas? is it a windows 7 problem (then this should be in windows topic sorry).
Thanks
Marc
Thanks
Marc
I'm on win 7 pro 64 bit and it runs fine for me.
Try completely uninstalling it and then install the latest version.
Thanks
Marc
Had this problem as well, realised i had downloaded the mobile ones instead, make sure you have the correct ones. Had exactly the same thing with the stereoscopic being the only thing on there to access, or wouldnt load at all.
Have done a clean wipe off all nvidia stuff then restarted pc and it started up all big and huge (like theer was no card) then i installed the lastest stuff off the website. Still nothing.
Anyone give me a correct link to the latest driver/software incase im downloading wrong one?
Its normal that everything goes big. Just right click and then go to screen resolution and drag it to the highest it will go
This can sometimes happen when a stick of ram is slightly faulty, its very rare though.
If all else fails and you have no idea, try with just 1 stick of ram.
