I can't decide!
OcUK Staff
12 Apr 2008
OcUK HQ
So this is what I have so far, I just cannot decide, I keep changing my mind all the time:
YOUR BASKET
1 x EVGA GeForce GTX 770 Superclock ACX 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2774-KR) £269.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £245.99
1 x Samsung Green 16GB (4x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual/Quad Channel Kit (MV-3V4G3D/US) £239.98
1 x Gigabyte G1.Sniper M5 Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £169.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £142.99
1 x Seasonic 660w '80 Plus Platinum' Modular Power Supply £129.95
1 x BitFenix Phenom MATX Cube Case - Midnight Black £74.95
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £71.99
1 x Gelid Solutions GC-3 10g Extreme Performance Thermal Compound £19.99
Total : £1,379.92 (includes shipping : £11.75).
So I need your help, what cooling would you go with? All suggestions welcome. :)
With so many options, even I am struggling to make my mind up!
Is a platinum PSU worth the premium over gold? I'm not sure. The Seasonic G-series 550w is £50 cheaper than the one you've got there.
That RAM is expensive, too. You could save enough to upgrade that 770 to a 780.
As for cooling, I'd want something discrete for an mATX case - a h80i or something like that.
The price doesn't bother me really, and as for the memory, I have the memory already, so don't really want to be changing it already as I have it in my current system. :)
I was thinking of one of the Corsair kits, not sure though, need fans too for the system. Maybe Noiseblocker?
what ever you do make sure you get some haribo. If not I would make a complaint to someone in cs :)
:p
Nice setup. What will you mostly be using it for 5UB? Gaming?
Yeah, and maybe the odd movie editing, as I want to learn that. :)
If your thinking of Single card setup only and not SLI then why not look at a H100 Or H100i for the top especialy if your doing heavy CPU work? Depends if you like the flexability on a single 120mm mount though or needing 240mm rad space. I keep looking at the mATX prodigy for single card with my H100.
It comes with an amazing 7 years warrenty, I'll be well jealous of you if you buy it 5UB :) I almost want my one to go pop so I can get one!
Should run a little cooler than a gold and I'm sure that over 7 years £50 of electric could be saved.
Do you really need the sammy greens? Great bragging rights but it makes me gip a little, they are almost a hundred pounds more per 8gb than when they first came out!
With the Samsung Greens, I have 16GB already. I got them cheap back in the day. Still going strong and gone up in price now. :)
OcUK Tech Labs Fathom All in One Custom Cooler 240mm
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit
Corsair Hydro H100i High Performance Liquid CPU Cooler
That is a Tech Labs Fathom in the case pretty much, in which our technical department has put it together for customers, so it is easy to install for customers. :)
Need fans too for the system. Maybe Noiseblocker?
I'd ask rjkoneill for his opinion, I remember him posting something about these fans a while ago.
you'll need a good bit of HD space for that, especially for HD video editing. I'd look for software that will use the 770's CUDA feature.
I have a BenQ 24" 120Hz.
I have hard drives already, and I think I will stick with a H100i and get some decent fans to go with the system.
And yes, I do just play CS. I am a bit of an addict. :p
