So I have the Phanteks Enthoo Evolve case and the rest of components are in my signature. Now Since i have built this machine i have struggled with the fan profiles and how to get them running how i would like. The gigabyte bios seems to be a bit crap, i cant get the fans to be individually controlled or even set up in a way thats acceptable. Its like its either far too loud or barely moving. The worst thing is i cant get the fans to ramp up slowly, so if i set up the fans to increase speed with temps its like it will ramp up then down then up then down non stop causing really bad noises.
Is there a way to stop this? I have a mix of 4pin and 3pin fans, i think thats half my problem, would a fan hub be of any use? Does anyone have a suggestion?
Im using a mix of Noctua 120mm and the stock Phanteks 140mm
