Short:
PC stopped booting - 3 quick bios beeps when windows 7 nearly loaded. - Will generally boot and work happily in safe mode.
Tried everything - Then reformatted - Problem still there - cant complete windows 7 install
Tried swapping ram sticks/graphics card/hard drive
The long:
I went on holiday for 2 weeks and when i got back my pc wouldn't boot.. (it was plugged in but the plug switch was off while i was away)
The problems are quite strange, sometimes it would get all the way to the login screen but as soon as you clicked on an icon to start typing the password the screen would turn off.. once i managed to login then 10 minutes later the screen turned off.. by going into standby i could get it back on but only for a few seconds.
Since then i haven't managed to get back into windows.. i tried lots of things even had problems getting into safe mode a few times. Would never load back into windows even with diagnostic startup selected in msconfig.
When loading after the windows logo the screen just turns off.. a few seconds later i get 3 fast bios beeps the computer restarts and does nothing.
In the end i gave up, backed up everything and reformatted... the initial set up worked ok.. then it rebooted and started the next bit and bam the screen went off again + same beeps.
Was really hoping it wasn't a hardware problem as it would work happily once it was in safe mode.
I plan on trying another power supply tomorrow.. but i am just really frustrated now ive spent a lot of time trying to get it sorted.
Just looking for help on advice on what the problem is and how to fix it/what to replace.
Thanks
The long:
Thanks
