i got 3 sound cards which one do i use?
23 Aug 2007
Hi all.
ok i was given 3 sounds cards today and there not new or anything but i thought they mite be better then my 5 year old onboard sound :D
ok i looked on google try to get much info as i can for each card
keep in mind have not tested them yet but i am sure they work lol
ok first one is a CMI 8738 5.1 6-CH Surround Sound 3D PCI Sound Card
Features :
* C-Media 8738 6-Channel PCI 3D Sound Card
* Provides audio fidelity that rivals movie theaters with 5.1-ch digital sound.
* Customize Internet audio with the power and surround sound of EAX audio technologies.
* Enjoy compelling 3D audio and 5.1 sound on multiple speakers series.
* 6 channel DAC for AC3 5.1 channel purpose
* 32bit PCI Bus Master, PCI 2.1 / PCI 2.2 compliant
* HRTF-base 3D positional audio, supporting DirectSoundTM3D, EAX and A3D interface
* Karaoke system enabled
* Supports multi-speaker output to 2 / 2.1 / 4 / 4.1 / 5.1 speakers
* Support EAXTM, Karaoke key, Echo sound effects
* High Performance Dual Game Port
* MPU401 compatible MIDI interface & GM
* Comply with Microsoft PC99 specification
* DLS-base Wavetable music synthesizer
* Fully Sound Blaster, Sound Blaster Pro compatible and Direct Sound compatible Connector
* Front-Out, Rear-Out, Center & LFE, Line-In, MIC-In and Game/MIDI port
next one is a CREATIVE LABS CT4810 Sound Blaster
General Features:
- Wave Table Synthesis: 128-voice wavetable synthesizer to deliver rich MIDI playback / 16 MIDI channels, 128 GM & GS compatible / 2MB, 4MB and 8MB wave-table sample sets included
- 3D Audio Technology: Broad title support for 3D audio standards including DirectSound, DirectSound3D and Environmental Audio in 2-speaker mode
- Stereo Digital Audio: 16-bit CD-quality recording and playback
- MIDI Interface/Joystick Port - Built-in 15-pin MIDI interface
- Connectors: Microphone in - MPC-3 CD Audio in - Line Level out - Auxiliary In/Rear Out - MIDI/Joystick port
- PCI interfac
And last one which i think the oldest.
But i could not find any info about but here a pic anyways lol
So all i would need to do is plug it in the PCI slot.
Then download drivers.
And then just plug in my 5.1 surround. ?
As on the sound boards them selfs there conection slots not sure what i would need to connect to them ?
thanks guys/gals for any help :)
ok thanks Solaris
i put got the driver and its does sound better :D
i put my connector into the line in port
but i can also use the green one but they both sound the same i think
ok i installed the wrong drivers lol
so now i got the proper drivers the inline dont work lol
But the green socket does
But it seems i need a diffant cable to make proper use of my surround sound
As the cable i using now is this one
with red and white connectors which go into my sound system
here a pic what i mean when it ask to install
rear speaker and jack indivdually ( so i take it i cant really have surround sound with my setup?
thanks for any help
how old is your motherboard? mobos these days are coming with ever more impressive onboard soundcards.
thanks for any help
you can do 5.1. All of those ports are stereo (s speakers per port). So you need to run cables for Front-Out, Rear-Out, Center & LFE to your amp.
