I gotta question :)
2 Jan 2011
Edinburgh, Scotland
need some opinions on this:
http://www.youtube.com/watch?v=zsVy9yl5LGw
how do you think it'll do if I put it as having two of the middle connections on the cpu block, one of the middle from the graphics card, the top going into the res, then the res to the pump, then the pump to the rad, then the rad to the graphics card? (with a stop fitting on the bottom obviously)
http://www.koolance.com/water-cooling/images/more/spl-xfr3_p0.jpg[IMG]
how do you think it'll do if I put it as having two of the middle connections on the cpu block, one of the middle from the graphics card, the top going into the res, then the res to the pump, then the pump to the rad, then the rad to the graphics card? (with a stop fitting on the bottom obviously)[/QUOTE]
The [COLOR="lime"][B]hotlinked[/B][/COLOR] [COLOR="lime"][B][/B][/COLOR]pic doesn't show ;)
EDIT: does now, but it's holinked
Also, just try it! :p
regardless of whether it leaks or not, it won't do what you want - you can't have both inlet and outlet of the CPU hooked up to this as you'll get no flow
if you want to do parallel of some description you'll need 2 separate splitters, one to split the feed from the pump and then a different one to bring them back together again
I'll need to wait for my mum to put my money in my account tomorrow first, then I'll order some watercooling stuff :D (not the koolance splitter)
