Why Oh Why did I not check the configurator and then find out that the waterblock I ordered would not fit my Sapphire 280X Vapor-X.....the snazzy little BIOS switch and two caps are fouling the fit.
All would be good had I not decided to remove the BIOS switch to solder on once I had fitted the block.
Am now sat with one ******* expensive paperweight.
Time to go buy me a reference 280X...
FUMING (at own self)
live and learn lol, if its under 14 days they will take it back mate
